Old 04-29-2013, 12:11 PM   #113 (permalink)
jime57
OurInsight - '06 Honda Insight
I haven't done anything to the underside of the car. I plan a full coroplast treatment. I'll do another tuft testing video of the bottom of the tail at that time. Probably won't get to it for another month or so, though.
Ah, good. I think a full underbelly helps a bit. Don't let the rear axel fake you out. I studied it a bit when I did my underbelly and thought it would clear the underbelly. Turns out I was correct - it doesn't touch. Of course, you will have to make cutouts for the spring perches and the lower shock mounts. Send me a PM when you get at it and I can give you some tips on mounting points, which are a bit scarce.
