+12 Constant power
NachtRitter thank you. I really appreciate your help. BTW the plug you 3 pin wiring you have pictures and outline here i found in my 92 honda civic vx to be +5v. My guino would not power up so then i tested it with mulitvmeter and its +5v so it's wired now to +12v but key on only. So next weekend i will either wire it to radio contant on +12v or i found big white and blue and black cable which i belive to be contact power in same spot. I can test it for power however question is are those wires already protected by 7.5 amp fuse or NOT. If not then i can't use it. MPGuino needs to be protected by fuse so it won't fry. Any ideas anyone about those 2 bigger wires if they are protected by fuse or are they before fuse box?
