Old 04-29-2013, 04:28 PM   #4 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.65 mpg (US)
You should be getting much better mileage than that. I suggest checking compression, preferably with a leakdown tester. If you are losing compression, the leakdown tester tells exactly where it is leaking. Also check the cam timing.
Have checked for brakes dragging or excessive rolling friction? Nothing should be hot after a highway run followed by light braking to a stop.
Ultragauge / Scangauge is your friend.
The Following User Says Thank You to JRMichler For This Useful Post:
Mira (04-30-2013)
