Cool cool many thanks!!! This is exactly what i need. Just curious you have 12 or 10 gal tank. Mine is 10 gal yet most ppl have 12 gal tank. Also are you calculating bigger size tire when calculating final mileage? This is important if you tweaking guino. How are you changing calculations on Microsec/Gallon when you change those values?
Tire size calculator
stock size 165/70/13
+1 size 175/70/13 so
if you odo reads 426 miles one needs to multiply x2.5% = 426x2.5%= 426+10.65= 436.65 odo final miles divided by total gals.
With bigger wheels tires roll too slow as tire is bigger therefore lower milage and 2.5% corrections needs to be applied. You probably know that.
