WD40 sweet bro. You're great man! How does your ODO mileage compare to Guino mileage after tire adjustment? the gal/sec number you want is probably that matches or is closest to those ODO match after tire mileage adj with Guino mileage. I'll put in some input as well after i get it installed properly this weekend. We'll figure this out. I really do appreciate your and Andrzej input. I have a starting point with your figures to tweak it now where wiki number was so off i would spent a month or more on getting it right so for that WD40 i thank you much. BTW what is our tires PSI if i may ask. I just bumped mine to 45psi. Max i can do is 50. In winter i ran 34psi. My goal is to run 50mpgs or plus constant which i can only do occasionally now.
