Originally Posted by stewie
Andrzej you're the man! Thank you. I found ISP port on the board. Is that the serial port in need to use to get into chip? How do i do that? Is there a guide for doing this? Are there any other functions that can be added to 0.86 guino as well. What would i use RPS for in terms of calibration?
There are many things you can add to MPGuino, right now I'm working on temp gauge, range gauge (how many km/miles you can ride with current FE and given tank size), and coast down time and distance meter.
If temp gauge will work as it should I think I'll include temperature management system into it. My guino will close & open grill accordingly to engine temp. Or I'm hoping it will
Anyway when I get my code working I'll post it here and maybe I'll add it to MPGuino wiki. Problem is that I'm working with "canadian" version, but code is very similar so it shouldn't be hard to include those changes into v0.86 "official" code. Maybe I'll make two versions of my code changes for canadian and official version. If there will be someone interested
