3rd test
Speedo test. Pre-test. I checked GPS speed and got closest i got few times was 8086 and 8090 and i settle on 8090 for testing.
1st test drive of 8090
11.80m guino x 8090vss = 95,462 / 11.794m gps = 8094 VSSP/M
2nd test. Changed vssp/m to 8094
2nd 14.53m x 8094 = 117,605.82 / 14.543m gps = 8086.764. Note close to my eye test on speed gps
2.5 mini test. Changed changed vssp/m to 8087 ( rounded up as it's closest)
3.37m guino x 8087 = 27253.19 / 3.372m gps = 8082
I will ignore this figure as 3.4 miles is not long enough distance.
3rd test with VSSP/M @ 8087
11.80m guino x 8087 = 95,426.6 / 11.795m gps = 8090
8094 was too high and 8090 was too low. To lower guino mil VSSPM needs to be bumped. Correct value is between 8090-8094. Will try 8092. I will then try usec number from wiki. Fill her up and reset all stats and test further. If and when i get some 50m+ trip i will retest both parameters again.
