4th mini test @ 8092
6.630m guino x 8092 / 6.636 gps ..right on to .xx digit. Will try 8091 to force it to .xxx closest match. Then will fill her up to top, zero out start testing default usec and do long distance test for both.
5th test @ 8091
11.860m guino x 8091 = ........ /11.873m gps = 8082.14
WTF!!!!! ....8091 is under and 8090 is over...over large distance this will widen by a lot. Is this margin of error in GPS reading? Must me and math give wide variety of different numbers. Either margino of errors or phone gps is fruther back from VSS sensor of the car so over longer distance this will throw off numbers.
