I think that mainly refers to tire wear tho. So the 7575 number you say you find accurate? You didn't test that one yet? Thing is if your odo on guino will be off by 20m by end of the tank your mpgs will be off too by much so i don't know. I will try this but i do not think vss will be changing on screen. That number is constant. This confused me here.
"To measure the VSS counts per mile get on the highway and find a mile marker and reset you VSS counts to zero. Drive ten miles as marked by the mile markers and note your VSS counts. Divide by ten to get your VSS counts per mile. Take an average of this process if you really want to nail it down, but I do not feel that is necessary. You may need to test this count every 6-12 months to readjust this number."
