Old 05-04-2013, 12:36 PM   #40 (permalink)
blownb310
blownb310's Avatar
Saab EV - '19 Chevy Bolt EV LT
Pierre - '07 ZENN MC2 Base
Originally Posted by nerdboy View Post
I'd be very interested to see how far you can get on the Volt's battery before having to burn dead dinosaurs!
Thank you Jeff. I haven't bought a Volt yet, but thanks to the courtesy of Mangino Chevrolet [in Amsterdam, NY] I had one to test drive for three days last weekend.
According to General Motors, the Volt's all-electric range with fully charged batteries varies from 25 to 50 miles depending on terrain, driving technique, and temperature. The official EPA rating is 36 miles. I made it 49 miles before the range extending 1.4 L gas engine seamlessly started [at speed you can't even feel it start.]
Here is my report card from the in dash display of the 49 mile drive.
I did not need to use any heating or cooling, hence the 100% Climate setting score. I read somewhere online that the pulse and glide [in neutral] technique works well on most EV's too. So I used that technique. But after the drive I read the in dash tutorial and it says that there is no advantage to doing that with the Volt. There is a very light regen that doesn't slow the car virtually at all that you're missing out on if you coast in neutral. I left some more range on the table as well because I did not realize until after I returned the car that there is a switch that allows you to turn off the daytime running lights. Also the tires were only at 34 psi. So I left a lot of range on the table, but that's part of the learning process.
2007 ZENN and 2019 Chevy Bolt EV 145,000 oil free miles to date.
