Thread: Insight gauges
Old 05-04-2013, 02:40 PM   #8 (permalink)
RedDevil
90 day: 57.12 mpg (US)
Originally Posted by jamesqf View Post
(about the Insight using but not counting gasoline vapor) But it should be able to compute that, and I think would do so as part of the emissions control system. It knows airflow and fuel injected, and has an oxygen sensor(s) in the exhaust. So X fuel + Y air should give Z O2. If it's more or less due to gasoline vapor, that's detected and X decreased in order to optimize emissions, no?
Maybe it could, but it would not know whether the enriched air is because of the recovery system or because of the overrich mixture of the car in front...
As it happens some G2 Insight owners have reported low FC readings just after filling and topping fuel. The most likely scenario is that their spills ended up enriching the recovery system, reducing the need for adding fuel in the usual way. Every now and then, after I fill up, it seems like the Insight runs almost by itself. The effect lasts just a mile or so.
