Old 05-04-2013, 03:26 PM   #10 (permalink)
freebeard
I do wonder if some (small) gain in reduced pressure drag might be achieve by directing the exhaust flow on a road car though.
I try not to think about that. Because exhaust gasses are hot and corrosive. I have centrifugal-pumped engine cooling air to work with though.
Lose the pumping loss and bump up the compression (ethanol, methanol or CNG?) and the SI engine will be more efficient than CI.
A Revolutionary Split-Cycle Design | Scuderi Engine
From their Engine Performance Data pdf:
1,400 RPM – Maximum Load
Brake Mean Effective Pressure [bar] — 9.3
Brake Specific Fuel Consumption (g/kW.hr) — 269
with equal sized cylinders. Mismatched cylinder displacement and 3.2 bar of 'Constant Knock Margin – 40% Turbo Efficiency' gains 13.4% on those figures.
