Originally Posted by bennelson
How do I MANUALLY control the rate of amperage while charging batteries.
You advice wanted!
Hi bennelson,
For this situation you want a "carbon pile" battery load tester. Its a big variable resistor with mammoth power dissipation.
![](http://ecomodder.com/forum/attachment.php?attachmentid=12995&stc=1&d=1367708168)
New from $100 to about $1000, used, maybe
ebay?
But you won't use it as intended. Use the carbon load as a way to reduce the current going into the dead batteries. You can probably figure out how to make it work for you.
-mort
