Thanks Andrzej. This is still werid to me. WD40 i have tip for you. You were talking about when you change settings guino freezes and you have to unplug power. That happened to me once and if you leave it alone, meaning frozen for 5-10 it will come back to previous setting but wont reset your stats data. Then one can change settings again and you don't have to loose tank data.
BTW for default usec value for vx setting for VSS is different too, so i guess it does make a difference. I am going to be using 8074 and tweak full tank on it. Default usec with 8074 vss seems right for my tank mpgs so far. It's really close to what i usually get. Perhaps we needed to tweak VSS as our tires are bigger size and usec usage is, should be the same as why would it be different.
Anyway did a test this morning and on 8074 milage with default wiki usec was slight by 0.05 over and i know for fact that gps has margin of error as once i didn't move at all and it moved 0.03 m. So technically this number could be bulls eye with default usec. But I decided to fiddle with it further and will try 8076.
