Progress
I have had to work on other projects lately, so the progress has been slow. Good news is that the other projects have been going well, so I'll be back on the little car soon. I did have a chance to get the front shock mounts done on one side. I made the lower front shock mount a two piece thing so I can replace it with a little different configuration if I need to adjust the ride height once I get it on it's feet. I don't think I'll need to, but if you can't build it accurate, build it adjustable.
These pictures are of the one side at full droop. I had the shocks laying around from another project, but they are fairly universal motorcycle shocks, so I can get others if I need to adjust spring rate later. If they happen to work, bonus!
TALON ยง
