Originally Posted by ErrForce
Well, round trip the elevation difference is 0.
Yes, but gravity is a lot less picky about dragging you down hill than lean burn / 5th gear ratio is about getting you up hill. If you have a lot of steep climbs that will keep you out of 5th or lean burn (in a VX etc), then you might as well save the money and buy a CX or some other non lean burn car rather than a VX/Insight.
