Old 01-01-2008, 10:56 PM   #15 (permalink)
AndrewJ
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
Originally Posted by eta View Post
Doesn't "deep cycle" really mean it is better at delivering long-term small amp loads, like powering an electric car? So if this battery can indeed be used in plug-in electric and hybrid cars, why isn't everyone using it?
In short, everyone would be using it if it really was impervious to 100% DOD (depth of discharge) cycles.
It seems to be just your run-of-the-mill sealed lead motorcycle battery. Basically it WILL be harmed by running it to below about 60% DOD, it just won't be AS harmed as a normal battery.
These types of batteries typically don't have the capacity to be used in EVs or hybrids. While they are certainly light compared to a normal car battery, they have a correspondingly lower capacity (EV's measure battery capacity in amp-hours, typically how many amps can be discharged for 20 hours)
Sealed lead batteries, wether they are valve-regulated, gel, or absorbed-glass-mat (AGM) have even lower capacities than traditional "Flooded" lead-acid batteries.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
