Old 05-08-2013, 12:49 PM   #23 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by riva2model64 View Post
Higher average speed (but probably below 60) is desired for hypermilers, but doesn't tell the full story, as higher average speed can be achieved by driving as aggressively as possible to the destination.
Like you say, it doesn't tell the whole story.
In the purest theoretical sense, lower speed is pretty much always better because aero drag is reduced.
That being said, often low average speed is indicative of lots of idle which, of course, is bad (assuming one leaves the engine on).
Also, if one is unfortunate enough to have an automatic transmission, low speed can mean lots of time without the torque converter locked up.
Also, it's worth noting that 50% 80 mph + 50% 0 mph is much different in FE than 100% 40 mph--even though average speed is the same.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
The Following 2 Users Say Thank You to Diesel_Dave For This Useful Post:
justme1969 (05-29-2013), UltArc (05-08-2013)
