Originally Posted by riva2model64
The argument of the writer seems to be that when a modern car coasts, the fuel injectors are off, so you are only experience engine resistance. When you shift into neutral, the fuel injectors turn back on to keep the engine in idle.
Okay so I drive a manual transmission, which is different... But in-gear coasting is 999MPG (actually infinite), which is just engine resistance. Neutral coasting with the engine idling is somewhere around 200MPG at ~40MPH.
So neutral coasting in an automatic, even with the engine still running, SHOULD give you pretty impressive MPG figures for the length of the coast.
