Old 05-09-2013, 08:50 PM   #2 (permalink)
War_Wagon
5 Gears of Fury
War_Wagon's Avatar
Spunky - '90 Honda Civic CX
90 day: 35.56 mpg (US)
That's a strong choice for wheels! As for the sticky throttle, there's a few things you can try. Get a can of WD40, climb under the dashboard, and spray the pivot point where the gas pedal mounts to the firewall. Then pop the hood, and have a look at the very top of the engine. You'll see the throttle cable going across the valve cover and to the throttle body. There is a bracket that holds the cable at the edge of the valve cover. Those tend to get bent when people remove the valve cover, and end up holding the cable on a weird angle so it can make it sticky. You want the cable to be nice and flat there pointing at the throttle body, not pointing down at it. The one in my '90 was bent, so I just smacked it with a hammer until the cable was sitting flatter and closer to the valve cover, and it actually made a difference. Maybe it will work for you too. Good luck!
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
The Following User Says Thank You to War_Wagon For This Useful Post:
ciderbarrel (05-09-2013)
