Old 05-10-2013, 02:01 AM   #7 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
A can of throttle body cleaner in and around the throttle body should help it run better as well.
Change the transmission oil, it takes regular motor oil in the transmission, synthetic works great, 0w30 makes it shift smoothly in the winter.
The 4 speeds were great, 4th gear is pretty high and is only out done by the CRX HF transmission but is most likely not worth the cost and work unless you need a new transmission anyway.
If you end up needing tires, 155/80 R13 are the best option.
You end up with one of my favorite cars.
The Following User Says Thank You to Ryland For This Useful Post:
ciderbarrel (05-10-2013)
