Originally Posted by jeff88
Thanks for the link! I've seen thid thread in the list, but for some reason have failed to read through it. Weird considering how similar our cars are.
Can you tell me more about the davies craig? I was looking at that one, but wasn't sure if it would work for me. Have you found it to work for your car, or is it a little overkill? I assume with the similarities of our cars, that I can pretty much match up to yours without any major problems.
What size engine do you have? I did a side-by-side comparison of our cars and they are both 1.8 I4, but you mention in your thread a different size, so I was confused.
Is all the work you done with the coroplast from the same trip out searching for it, or have you made multiple trips? (You only mention one time of going out and getting some.)
Also, great job on the work you have done.
my engine is 1.5l but the pump is to power full thats why I reduce its power by wiring 4 diodes.
I get my coroplast in 3 differents trips
Best Tank (1557.2 Km): 2.57 LHK (91.63 MPG (US) )
Best Highway Trip (~36.8 Km): 2.16 LHK (109 MPG (US) )
Best Commute Trip avg (73.8 Km ): 2.33 LHK (101 MPG (US) )
Echo-Troll Modding Thread
I know i dont have a very good write-up
no lean-burn? no good gear ratio? p&g is the answer
MPG=1 TIME=0
