One could do grill shutters, like on newer cars, that open up with brake light activation (relay clicks on, actuator opens vents) that pipes to the front brakes only. Quite a bit more work, but would be very effective and keep aerodynamics when you need them. Plus, would help you stop a bit better when the vents open!
