Old 05-10-2013, 10:52 AM   #294 (permalink)
NoD~
NoD~'s Avatar
Frogger - '00 Honda Insight Gas Only (unHybrid)
90 day: 68.51 mpg (US)
Is that your next project after converting your Neon?
I would be worried about them catching too much air, since people already lose moon disks.
Ha! It'll be a while before I get the Neon done... I got about 3 active projects on it already, plus 2-3 more planned before I could even touch such a project! Active grill shutters, for sure... brake cooling? I've never had a problem (though I don't have my wheels covered yet) and, since the vast majority of my driving requires no major brake usage, I think I'll be ok. Also, my car is around 400lbs less than stock. A car that weighs less won't require as much from its braking system.
Though, this whole thing gave me an idea... when I do make active grill shutters for the front end to the radiator, I'll likely tie in the opening of the shutters to the brake light for ...more stopping power? I figure, if you are going to be slowing down at all, might as well use all you got!
