Old 05-10-2013, 03:47 PM   #11 (permalink)
Phantom
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
It is best to pull the air throught the radiator if you have the room. Then you can build a shroud so that the fans will force air through the whole radiator. Without a shroud or with the fans in front of the radiator then you are effectively only using the area that the fan covers.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
