Old 05-11-2013, 07:25 AM   #69 (permalink)
volkov
volkov's Avatar
S2 E-RST - '86 Ford Escort RST Ghia
I'm working on two Mpguino at the moment.
One is in the car (a little modified 0.82M) to set the values and calibration, almost done, I've done more than 250km and only got 100m difference on the VSS signal!!!
The fuel need another full refill, there the diff is 5-10%
The other setup is my table and I'm working on some mods.
-I've removed the first zeros
-add a temp sensor using a d18b20 one wire sensor
-add a screen saver: after time out, this screen appears
-add L/H in the L/100km page when the car is stopped, and display --- when the car is stoped and the engine is not running.
My other plan is to add RTC an display it on the screen saver screen
It's on it way from China
