Old 05-11-2013, 05:54 PM   #17 (permalink)
aerohead
hitch and radii
Originally Posted by mackerel View Post
So the closet door is external, on the back side? I'm trying to figure if I'd have enough room for a ball hitch as well. At this time, I have no proper bumper. The tail lights are in a piece of very thin aluminum plate that hangs down from the bed frame. Sometimes I've imagined a box for the spare (and other emergency supplies) in that space. But the draw bar to hold the ball/receiver would have to be low enough to make a gap big enough for the tire to get through.
The other question is: How big of radius is enough to avoid vortices?
I just added Zip tape on the seams, and between the cab and front edge of the cap. I'll need some kind of back window, and some bug screen on the front window facing the back window of the cab. I'm going to add some reflective insulation (probably just mylar) on the inside too. Cross country to Chicago in two days, and Monday night is supposed to be near freezing where I'll be then.
To do the hitch would probably require a yoke to circumscribe the closet area while providing the structural hard point for he ball.
My lights and license plate are to side of door.
As to the radii,since your roofline is decelerating the air closer to the velocity on the sides,you may be looking at weak vortices if they do exist.
Someone following in a rain would be able to spot them.Tufts along the top sides should point toward the roof.Kamm's cars had this.
I wouldn't be too concerned until we get that full-scale wind tunnel where we can properly 'tune' everything.
Really like what you're doing!
