Old 05-12-2013, 01:03 PM   #11 (permalink)
jere
camry wagon - '95 toyota camry LE
90 day: 23.99 mpg (US)
Originally Posted by Old Mechanic View Post
On the other hand while riding a Cab in Baltimore when Pop was having some surgery done at Johns Hopkins, I noticed that every single Cab had a CEL and ABS warning lights on and the drivers just seemed to ignore them.
regards
Mech
I know with my cab company the drivers pull the fuses most of the time so as not to run up the mileage. When the odometer fuse gets pulled it trips the cel light.
To SentraSE-R did you change the brand of tires or could they be another gen of the same tire with more weight different compound? If your O2 was bad in a Sentra your MPG would be a lot worse I would think.
