Old 05-12-2013, 04:07 PM   #20 (permalink)
jere
camry wagon - '95 toyota camry LE
90 day: 23.99 mpg (US)
The T-stat is mechanical and doesn't talk to the ECM. It is usually just mounted in a housing that is completely separate. You can just leave the housing and take the T-stat out.
It isn't good for the life of the EWP to be switched on and off, that is why the pulse width modulation controller should be used.
