What I love in MPGuino's project is that you can customize it any way you need/like/want.
I like the idea of screen saver maybe the logo of EM? ;-)
I don't need RTC because I have OEM clock
I've build in temp measurement code into my MPGuino using OEM engine's temp sensor (that one used for daschboard) because I couldn't find a good way to mount d18b20 within the coolant flow.
I need to make some more changes to my installation, because I want to build whole MPGuino into a instrument cluster, tghen check and calibrate the temp sensor and I'll be ready to publish everything here.
Volkov,
Will you post your changes to the code?
