Old 05-13-2013, 10:56 AM   #60 (permalink)
stewie
stewie's Avatar
Milano Red VX - '92 Honda Civic VX
90 day: 50.15 mpg (US)
Originally Posted by WD40 View Post
stewie:
I was trying to go for a tank reading but forgot to read the total tank mileage on the mpguino before i reset it .. lol
I took readings along the way to compare actual to it and it seemed pretty close..
mpguino = 546.2757 klm
actual = 545.4537 klm
hows your tank readings going
WD40 i did another run and 8087 or 8088 matches with my new usec. I also checked the calculation the way Andrzej suggested and came up with same number. What VSSPM and usec numbers you're running??? I was thinking and your usec number will be different as you are getting better mpgs due to psi, lighter car weight and mods, however since we have same 175 tires our VSSPM should be same or close (as worn tires affect as well). Andrzej sweet. Thank you. I will try to run my as accurate as possible. MPGS numbers will very due to hotter tempetures anyway which are coming soon.
