Old 05-13-2013, 07:37 PM   #22 (permalink)
101Volts
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 18.73 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
We had the air filter and spark plugs changed. I also put more air in the tires. I think that will be it for modding the van for a while, Unless I can find something cheap to do.
And I only recently with this last fillup started to adjust the ScanGauge at fairly properly; Until recently, I'd only zeroed the tank for a baseline though I thought it was higher when I started this thread.
For some reason, The SGII is reading wonky when I check the tank info - It says we went through over 1,200 gallons, Got 2.7 MPG or so and that the water temperature is under 40 below. Why is it doing that?
