Thread: 91 civic si
Old 05-13-2013, 09:45 PM   #36 (permalink)
Stacygifford
Eco Storm Chaser
Stacygifford's Avatar
Nemo - '87 Ford Mustang GT
90 day: 27.26 mpg (US)
K-sight - '02 Honda Insight
90 day: 39.24 mpg (US)
Exclamation It works!!!!!
IT WORKS!!!!!!!!
Awesome news ! My cylinder management system actually works!
<object width="640" height="360"><param name="movie" value="http://www.youtube.com/v/hjAGmZx-lyc?hl=en_US&amp;version=3"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/hjAGmZx-lyc?hl=en_US&amp;version=3" type="application/x-shockwave-flash" width="640" height="360" allowscriptaccess="always" allowfullscreen="true"></embed></object>
Variable displacement experiment. 91 Civic Si B18 - YouTube
The first thing that I did was checked the resistance of my injectors. They were all between 2.4 and 2.6 ohms. (92 - 95 should be around 8 ohms FYI) it being that I could not find any 2.5 Ohm resistors that could handle more than 1/4 watt of power I wired four 1/2 watt 10 Ohm resistors in parallel, which yields a final resistance of 2.5 ohms.
The next thing that I did was remove the plug from injector one and unplugged the two plugs in the wiring harness that go to the injectors. (see next picture)
The green one goes to the resistor box (nonexistent in 92-95 Hondas) the large white plug is where you test what wire goes to where. They are also color coded, I always check with a volt meter to be certain before I go cutting the wiring harness.
To make sure that this would fool the computer, and to prevent myself from wasting a few hours of wire in something that would not work; I simply put the resistor directly on the cut wires and completely bypass the injector.
I went in the car turned the key and to my amazement it started with no check engine light!!!
Granted, it did run a little rough or in just three cylinders Lol..
Now, it was just time to wire it all in!
To make the alternate circuit I used a DPDT switch from radio shack (On-Off-On) I was hoping to find a DPST On-On switch, but it is just as easy to skip the center of position.
On this style switch there are six terminals. The three on the left and the three on the right are completely independent of one another(one circuit for each injector)
On the upper two terminals I connected the resistors and spliced into the constant power to injectors 1 & 4
The middle terminal I connected to the ecu side of the injector ground wire (brown in the first picture)
And on the lower terminals connected to the injector side of the ground wire (brown in the first picture)
As a side note the wire color for cylinder number four is yellow.
Listed tools and items needed
• Resistors equal to resistance of injectors (2.5 ohm in 88-91 civic 8 ohm in 92-95) ~$4*
• Soldering iron with Souder
• Good wire (12-18 gauge, I used about 30 feet....) ~$6*
• Heat shrink ~$4*
• Wire cutters/ strippers
• 1 DPDT On-Off-On switch (Or a DPST On-On switch) ~$4*
* cost is assumed if buying new.
Most people who do wiring should have all of these with the exception to the switch and possibly resistors, all I purchase were the resistors and the switch.
