Old 05-14-2013, 05:52 PM   #143 (permalink)
aerohead
noise
Originally Posted by pascal28 View Post
Serrated nozzles on aircraft engines are for noise reduction. They have a slight efficiency penalty. They were put on the engines (Trent 1000 & GEnX) powering the Boeing 787 due to concerns that its composite fuselage would transmit more noise than a conventional aluminum one. They reduce noise by encouraging mixing between the hot & bypass flow and between the bypass and free-stream air. This reduces the shear force and consequential noise generation.
I believe that this technology is an outgrowth of NASA's acoustic and body-morphing research of raptors,specifically the peregrine falcon and one type of owl.(please see PBS' NOVA's 'Raptor Force')
Critter-cams attached to both birds revealed damping abilities owed to aft-body feather and down architecture.
Earliest winglet technology was also modeled after buzzard wingtip feathers which not only cut drag,but also attenuated noise propagation from the reduced shearing forces.
freebeard (05-14-2013)
