05-15-2013, 11:22 AM
#6101 (permalink)
Originally Posted by Nevyn
Glad you're home safe and sound! I just finished re-reading this thread (yes, the WHOLE THING) and will hopefully be able to be somewhat helpful once again.
My version 1A of the 1kA IGBT board seems to be working. Other than backwards LED, that is. Man, I was soldering last night and forgot to fix that! Derp!
RTD connection works all good, except for the "restart" command - all it does is break communication! Such is life. Throttle input seems to work, current sensor seems to work (took me a while to read through the thread and find the pinouts for the 3-wire Melexis compared to the 4-pin header on my board!), so I think I'm ready to try and interface it with the old BG2A IGBT driver board!
Finally, Paul, one of your early testers is testing! I'm only what, 2 years behind Isaac_Alaska?
What software version are you using? I think Paul changed something in anything above 1.1b and that broke the restart command.
-Adam
