Put a test light on your VSS and see if you see any changes during normal driving and engine braking. I believe the computer uses the fuel cut-off during engine braking because it combines the TPS readings with the VSS readings so that may have something to do with it, maybe the readings are off from normal and it only can see a descrepency (sp?) during engine braking.
