Originally Posted by California98Civic
You are right that time will tell, but I'd predict that Connclark is correct about the aero costs. Your best way to find out will be with A-B-A testing. I love your initiative and this is close to a mod I want to do, but I plan for 2mm thick and flexible panels that will form-fit to the roof. This thicker panel mounted on the roof rack looks a little like a wing. I think if there is any way for you to do it and are committed to this hardware, you could move it to the trunklid. You might even make it a bit of a trunklid flat spoiler if it won't fit on the available surface. There would still be aero issues there, but I think they'd be less significant that your current wing-like roof mounting. Maybe others will chime in pointers.
Did you follow through with this? I ask because I have considered doing the same thing, and mounting solar panels on the roof of my truck and the topper. I will study this setup some more, I think.
