Old 05-19-2013, 11:29 AM   #3 (permalink)
asdrewq1
Managed to find the wiring diagram for my car showing the injectors:
Forum won't let me post links, but if you paste this in address bar you can see it:
gtfour.supras.org.nz/pics/ECU1.pdf
I have tapped the injector on the right hand side of the injectors on that diagram, between the injector and the ECU pins (top of the page). If i'm reading it right I have connected in the right place? The other injector wire leads to the EFI resistor, ignition switch, fuse and battery +ve.
