This setting tells guino if it should wait for high or low state. So when you've change it you've changed your guino to count injector open time instead of the time when it was closed.
That's why you had reverse readings.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
