Old 05-20-2013, 09:53 AM   #17 (permalink)
oil pan 4
Originally Posted by pete c View Post
I don't have any actual stats, but, I believe that statement is backwards. I believe that a properly sized turbo uses its waste gate only at high loads.
Yes this is correct.
I don't not use a waste gate. I limit boost by over sizing the turbo a bit and by fueling then making sure the engine can take the amount of boost it gets fed.
On a gas engine this isn't really an opption.
