Old 05-20-2013, 01:23 PM   #18 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Compound turbos have been used a lot. They use the turbine shaft to mechanically drive the load, parallel with the flywheel. Lots of WWII airplane engines used them.
Until recently, Detroit Diesel 15L engines had a compound turbo that drove the gear train, but it seems they have ditched it now. There's probably a good reason for it.
EDIT: The DD16 (600 HP) still uses turbo compounding.
http://www.demanddetroit.com/engines/dd16/default.aspx
The Following User Says Thank You to mechman600 For This Useful Post:
pgfpro (05-20-2013)
