Old 05-20-2013, 01:50 PM   #13 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
MPPT Charging
Originally Posted by MPaulHolmes View Post
DISCLAIMER: This made sense to me last night, after being in the sun all day, so I could be wrong. haha:
Yes, since it's feeding a 48v battery bank, the voltage is approximately constant. Well, higher current into the batteries causes the battery bank voltage to go up slightly because of the internal resistance. Am I thinking about this wrong?
I guess charging a battery bank is close enough to constant output voltage. It will be a narrow range of output voltage ...
So maximizing output current ... will maximize the input V * I for the buck converter ... that follows!
I don't know how you have the PV arrays wired. Do you need a buck/boost circuit for cloudy days ... wait ... you said Arizona. Never mind!
The Following User Says Thank You to thingstodo For This Useful Post:
MPaulHolmes (05-20-2013)
