Old 05-20-2013, 01:13 PM   #19 (permalink)
jamesqf
Originally Posted by pete c View Post
There is one other problem here. How do you harness power from a device that is spinning at crazy rpms and is very hot? You do it with a rather complicated transmission that will cause turbo lag like you've never seen.
How do airplanes harness power from turbojet engines? Which are, after all, basically scaled-up turbochargers pushing bypass air out the back end instead of stuffing it in the cylinders of an IC engine.
Simplest answer is that you don't do it mechanically at all. Turbine shaft is mated to the rotor of an alternator, which generates electricity. By switching the alternator so it only generates at higher exhaust flow, you pretty much eliminate any excess turbo lag. If you happen to have a hybrid, you can store the electricity for later use...
