Old 05-20-2013, 05:02 PM   #20 (permalink)
NoD~
NoD~'s Avatar
Frogger - '00 Honda Insight Gas Only (unHybrid)
90 day: 68.51 mpg (US)
Power Steering racks aren't much different from car to car, especially in the 90's.
Basically, here are your options...
-Keep power steering in tact: Easiest to do, Easiest to steer, worst for MPG, cheapest to do
-Change pulley(ratio): Medium amount of work, Easy to steer, better MPG, medium price to do
-Remove PS Belt: Easy to do, hardest to steer, Good MPG, Likely just as cheap
-Remove PS pump/loop lines: Medium amount of work, medium to steer, Great MPG, Likely just as cheap
-Replace PS rack with Manual rack: Medium-Most amount of work, med-easiest to steer, Great MPG, Most expensive
-Dissect/Rebuild PS Rack: Most amount of work, med-easiest to steer, Great MPG, Possible mild expenses
(MPG goes from Good to Great once you remove the extra weight of the PS system, hence why the improvement.)
There you go. From the least amount of work involved to the most. I have done all but install an actual manual rack (hard to find for my car). I would recommend taking off the belt to see if you like the gains first. If you loop the lines, steering becomes much easier. If you pull apart the rack and remove the piston/properly grease things up in there, it seems pretty easy IMO to steer. Only time it can be tough to steer is a completely dead stop, but it depends on your tires and your weight.
As for the pulley change, there are a few things to note about it. If you can find an underdrive pulley for your car, it will likely reduce the weight of the pulley (rotation mass, replacing heavy cast steel with machined aluminum), but also send less engine power to alt/ps/ac system by rotating those components slower. I run one on nearly every car I own. As long as your pulley isn't required for internal engine balance, you should be ok to do it. I have one on my DD and it only runs the alternator at this point.
Also, there are other benefits of removing the PS system...
-Weight reduction = more MPG (it's probably ~15lbs of pump/lines/fluid reservoir, pending car)
-1 less belt to change/tighten
-1 less fluid to maintain/leak
-Less engine clutter. It's SO much nicer to work on an engine w/o a PS pump, reservoir, and lines in the way!
-Works your arms more. Face it, who's got time for the gym?
As for rack lubrication: I have yet to hear of anybody who got out all the fluid out of the rack by forcing the piston left/right all the way and have failure because of this. Of course, this is assuming you either loop the lines or seal up the system somehow. If you add any fluid at all, you are going to have a much harder time turning because you will be manually forcing that fluid to move to the opposing chamber.
See this diagram:
The Following User Says Thank You to NoD~ For This Useful Post:
redpoint5 (05-20-2013)
