I have a volt meter hooked up so I can monitor lean burn. I am going from 55-70 depending I've got some rolling hills so gotta try to get speed to keep seep up long gradual grades. We sold our house so belly pan is on hold. I do have rolls of aluminum coil stock. 24in wide by 50foot it's what siders use to wrap window and door casings. So I thought possibly that with some stiffing ribs or even just that with a few aluminum angel run down the car. Hummm. Turbo If you want I got a front sway bar for a 96-00 civic. I only have the bar and brackets I think. Come and get it. Or I could ship if you want. Let me know. I was told it would fit a 92 but no. You need the back half of he front lower arms with a hole in them. They are from any 92-00 that has a bar. Well see about this tank it's been a little warmer and I've run less short trips so we will see. Right now it's getting hot and I'm turning into a baby I need a/c fixed.
