Old 05-21-2013, 03:32 AM   #18 (permalink)
Occasionally6
Originally Posted by NoD~ View Post
The fan will kick on if you have the AC going. AC kicks on if you get defrost going... so you can have that fan kicking on summer/winter due to that as well.
That will help engine warm up (a bit) because the condenser is rejecting heat into the airflow ahead of the engine radiator.
If you have a PWM controlled fan, what is need is a duty cycle meter. A cheap way of getting that would be an adapted DMM but you could build something to do it.
