Old 05-21-2013, 04:02 PM   #298 (permalink)
bschloop
sr185 bullet - '81 Yamaha SR185 streamliner
Team Streamliner
90 day: 96.35 mpg (US)
Sunny Colarado - '06 Chevrolet Colarado WT
90 day: 24.18 mpg (US)
cbr250s - '12 Honda cbr250
90 day: 115.29 mpg (US)
Most 4wd trucks use a transfer case bolted to the rear of the stock transmission. you should be able to get just a transfer case. an advantage to this is that many transfer cases are chain driven on the inside, so you could play with ratios much easier. you would need to get a shorter driveshaft, but they should be easily available.
If the 4wd is a shift on the fly type like most modern ones, you could use the transfer case selector to engage/disengage your electric drive. some transfer cases even have 2 speeds, a super low gear for pulling, and a 1-1 gear for regular driving.
The Following User Says Thank You to bschloop For This Useful Post:
a8ksh4 (05-21-2013)
