Looks nice. Hook up a mpguino or even a volt meter to the 02 and you'll see how to keep it in lean burn. It's the secret. Until I figured it out I was at the 40-45 mark. Sometimes you need to be in 4 th on the freeway to keep the lean burn. It's pin d14 and d16. Orange with stripe and blue with a stripe I believe. There is a lengthy post on how to do it. Good luck. what rpms are you turning on freeway at say 65? 2000-2100 them you at least have the right trans.
