They do have field data (still grain-of-salt) that shows improved collection. I'm of the mind this can work if done properly.
Reminds me of this:
In both cases, you're asking the wind to squeeze itself into a tighter space rather than going around. If the taper is right, it will. And it will gain speed as it goes through, allowing you to generate more power from smaller turbines.
