Thread: The Scrapcento
Old 05-22-2013, 03:32 PM   #71 (permalink)
RedDevil
90 day: 56.53 mpg (US)
Originally Posted by maczo View Post
That's the option I'm considering the most, but I don't have an idea how to cover the caps once I get them. I'd like it to be light enough not to throw the tires off-balance, but still it has to be durable.
It depends on what they look like. Somewhere on this site I've seen pictures of caps that were cut so that only the ring with the hub clips remained, and a flat plate was mounted onto them. The originals had curved spokes.
Mine form a slightly convex plane with just some big gaps:
I was considering buying some thin Lexan sheet and cut triangles and a small circle from that and glue them in the spoke holes and center, level with the spokes.
I might also just cut big circles and make 8 radial cuts to allow the plate to bend inward towards the edges. Or I might just grind the caps flat and glue an uncut circle onto that.
If only I could find time for that and some 50 other urgent things to do...
